Anyone know where to buy a serial connector
Need to find a seller of serial plug end to make lead up for my tech-edge WB02 controller to alter the settings on it...
Does anyone know of a seller or does anyone have one that I could borrow or buy?
Many thanks for any help...
Rob
Maplins should have what you're after
Had a look but could not find what I was looking for :(
but they don;t seem too... ??? might have to call them instead...
Did you mean a "D" Type connector
clickhere
loads if yer d a proper search  :p
I just need the serial connector so that I can make a cable up...
I made a lead up with bits from Maplins. The plug/socket are one item and then I bought the hoods as separate items. For my ECU there were only 3-wires from plug to socket plus a couple of close tolerance resistors that fitted inside the hood.
Kerry
Good FIND!
Many thanks :D
