Looking for a wide body westy, not got a lot of money to spend (5k ish) let me know what you got.
Neil
friend? didn't think you had any :p:p:p
Buzz
The car was built in 1994 and is a very reliable road car and great fun for track days!
The car was the first of three built in quick succession for friends by a professional motor engineer.
The car is  a wide-bodied car with detachable rear arches and cycle wings fitted. All the wings carry carbon fibre effect inserts.
Vauxhall 2.0litre 16v is fitted ex- Astra GSi that had been a rear end write off. This was fitted with 2 x 45 DCOE Webers with K & N Air Filters after rebuilding / balancing incorporating Cosworth bolts etc. Dyno reading 162 bhp at 6200 rpm; Oil cooler fitted & electric cooling fan. Copper 4 branch into one exhaust to side stainless silencer. A spare quick change "effective" silencer is also available for 'quiet' days! An engine immobiliser is fitted for security. The vehicle has had an Mobil One engine oil change completed  and an annual service prior to each M.o.T
The gearbox is a 5 speed Getrag ex Opal Manta
Suspension is independent all round with SPAX adjustable dampers; Chromed Coil Springs on the front and a Sierra L.S.D.
Alloy wheels are Compomotive 15" Dia Tyres 195 x 50 are new Yokohama A509 There are 2 new and unused x 16" Dia matching wheels available too!
Disc Brakes on each corner are Brembo four pots, cross drilled on the front with Ferodo racing pads all round( I've some new spare pads too!)Brake lines are braided.
The body is BRG with a yellow nose cone & bonnet is on a powder coated wide chassis. There is a green tinted screen fitted & a spare clear screen available on sale. The interior trim is black and the high backed vinyl seats are trimmed with yellow. The 12" Momo steering wheel is leather covered connects to the Kwikrak ; Willans seat belts are fitted. There is a full tonneau and side screens but no other weather gear. the volt meter; fuel gauge; oil pressure gauge & water temp together with the Rev Counter & speedo instruments are white faced VDO items. There is a stainless steel roll bar fitted.
The current M.o.T expires on 25 September 2006 & the car is taxed until end September 2006 The speedo read 5700 miles!
The car has always been garaged and covered by a fitted dust sheet with a battery conditioner to maintain the electric’s in A1 condition. There is also a fitted green coloured waterproof car cover available with the car.
I want £7500 if you can't afford it perhaps another might?
Hi Malcolm
Sounds a great car, but I would be tempted to remove you reg and/or chassis number from your post.
You never know who may be looking on public forums.
A long shot I know but worth a mention.
Regards
Rob
I've taken your advice....thanks...I'm a bit new to this!
No worries welcome on board.....
Just between me and you though, I'm the only normal on on here  :t-up:  :down:
:0
Are you what passes for 'normal' in Chesterfield? ???
Thank God I'm miles away :)
Andy
probably above average for Ches-vegas  :t-up:  :t-up:  :t-up:
Normal !
Isnt that Ab ?
:p
I'm definitely staying well away then :)
Andy
Sound's a great car and good value, but I think that it's a bit more than he's looking to spend but I will pass you details on
Neil
Buzz
cheers - next time you need something taping to your head don't come to me  :arse:  :arse:
:0
Andy
Is that a Banjo I hear??? :D
Andy
I knew Rob looked familiar first time I met him... :D
Andy
