Hammy Posted March 4, 2006 Share Posted March 4, 2006 hi, this may sound a bit dumb -just managed to get my Westfield fired up this pm, it runs ( ye ha etc)! However I've noticed that with the Engine not running I can hear the fuel pump ticking probably one or two beats per second -is this normal ? ( I thought it would have stopped once pressure was up and the carbs full). I do not know what the make of pump is- it has a square body and is mounted under the carbs, feeding a regulator. The engine runs fine and shows no sign of over fueling, tick over is steady. while I'm here - I'm running twin 40's on a X flow - Do I need a choke for cold starts ? thx Paul. Quote Link to comment Share on other sites More sharing options...
philsugrue Posted March 4, 2006 Share Posted March 4, 2006 mine makes a ticking noise. i dont think its anything to worry about I run webber 40's on an 1800 zetec and have no need for a choke HTH Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted March 4, 2006 Share Posted March 4, 2006 Fuel pump ticking is good and ticker gets louder quicker when running low on fuel No need for choke usually - just a quick pump on gas pedal to prime it and off you go I do not know what the make of pump is- it has a square body and is mounted under the carbs Often mounted at rear near fuel tank ?? is it a brass bodied unit ? Check fuel line and see if there's an inline filter between tank and fuel pump fit one in Quote Link to comment Share on other sites More sharing options...
philsugrue Posted March 4, 2006 Share Posted March 4, 2006 Fuel pump ticking is good and ticker gets louder quicker when running low on fuel by the time my pump gets a louder tick....i'm out of fuel Quote Link to comment Share on other sites More sharing options...
Hammy Posted March 4, 2006 Author Share Posted March 4, 2006 Sounds as though all is ok, which is good news - It may be brass bodied (looks milled from a rectangular block)... but its too dark to look now. Quote Link to comment Share on other sites More sharing options...
Mid life crisis Posted March 4, 2006 Share Posted March 4, 2006 Fuel pump ticking is good and ticker gets louder quicker when running low on fuel by the time my pump gets a louder tick....i'm out of fuel Yep I can endorse that! ended up pushing my car up a Dual carriageway in Bury Lancs last Saturday. Lotts of cliking from the fuel pump. Must get my fuel gauge sorted!!!. Quote Link to comment Share on other sites More sharing options...
