Front Hub bearings
I am trying to get hold of some wheel bearings today and rang around a few motor factors in my area. Asking for cortina bearings get some interesting reactions. One has said bring the old one in and we will match it, what old one! I offered to take in hub and he said that will do, I am jsut a little concerned, should I do this?
Does anyone know what o.d. and i.d. and any other pertinent information I need.
Just overhauled my hubs. Part number BRT 266 at £8.31 per set. I have thrown the old bearings and boxes away, but you could use that number to get a cross reference.
Hope that helps.
Hope that helps.
Thanks mate, I shall try that. Cheers.
vkba 505 is the skf ref from the brt ref
cortina 70-72front
escort 74-80front
301280 OPTIMAL
4031185212809 OPTIMAL
5 007 026 OE Ford
505 SKF
5208 RUVILLE
7814 HK
GK0026405 SPIDAN
HK7814 HK AUTOTEILE
QWB115C QUINTON HAZE
some more codes to help...
cortina 70-72front
escort 74-80front
301280 OPTIMAL
5 007 026 OE Ford
505 SKF
5208 RUVILLE
7814 HK
GK0026405 SPIDAN
HK7814 HK AUTOTEILE
Thanks the motor factor did not recognise BRT 266 as a ford part number, I am sure one of these will help. I just asked for a cortina Mk3/4/5 in the end. But I hall use these to confirm it is the right one.
Try also
Lockheed delphi part number BK133 for Hub bearing
It's also listed under Hyundai Stellar as well as Ford Cortina
David
Have you found any bearings? I have a pair of genuine Ford kits complete with seals.I think that i may also have new disc to hub bolts and lock tabs.
I picked the bearing kit up from the motor factors. Thanks.
