Induction bits
New unused Westfield Inlet Manifold for twin Webers/Dellortos or DCOE mounting twin Throttle bodies (e.g. Jenvey SB or SH).  £125+VAT new.  £50.  SOLD
New Unused Ford Inlet Plenum for 130PS Escort Pt No 928F-9425KE, including Air Temp Sensor F20F-12A697-AA and gasket 928F-9441DB (K743D), but no IACV or throttle body.  £40
New Unused injector mounting plate Pt No 928F-31J524 plus s/h Mundano Fuel Rail (regulator suspect, but I will throw in the injectors as well if I can find them).  As used on Westfield demonstrator showing Factory Plenum Design at Stoneleigh  £25
Unused Gaskets - All for Zetec (£10 the set, or will split - no jokes, please, all gaskets still in one piece ;) ):
Ford 928F-9441DB (K743D) Pattern copy - fits between 130PS Escort plenum and injector mounting plate.
Ford 928F-9P848AD (K743D) + Pattern copy - fits between Escort Plenum and Throttle Body
Ford 928M-9941GB (E510D) + Pattern copy - fits between injector mounting plate and head
Pattern Exhaust Gasket
BTTT.  More detail added and price cut.
Manifold provisionally sold to blankczechbook
BTTT
Apart from the manifold, everything else is to be chucked in with the engine listed separately and offered on eBay tomorrow.
