Brake master cylinder
I have a 1989 se with a escort mk1 pedal box, i have been told the master cylinder is off a mk111 cortina is this correct ?. Where can i get one at reasonable money, i have been quoted £150 (SOUNDS A LOT TO ME) exchange ,£2oo not exchange!!!!!!
That is a lot. You could get the AP racing one from Westfield for about that!
Andy
Andy
£197.40  inclusive.
Westfield AP MBC
I don't think the AP cylinder is a straight swap though.
The best place to try for a replacement for the Mk3 'Tina master cylinder would probably be Brakes International.
I still need to find out if it is definatly a mk111 cortina one
try westfield, think they are just over £110 inc ??
any old ford specialist is worth a try.
pretty certain it was the same one on the reliant robin (honest)
does it look like this
at010046 cylinder 19.05mm dia
at054719 rebuild kit.
some extra cross ref numbers for you...
1563516 OE Ford
4006633007856 ATE
6016236 OE Ford
6069635 OE Ford
AT03211905253 ATE
if so a rebuild kit could work out at about 25quid, or a new ate master cylinder - half what you were looking at.. without exchange!
these are full price normal retail prices i am quoting..
i made the mistake of not searching around hard enough after my went all soft, and after changing the cylinder for another type - i then found this from my supplier.
now its hard again folks. :D
My 89 chassis uses the Mk3 Cortina non servo master cyl.
If I were buying a replacement I would have the AP unit from Westfield and mod the pedal box to make it fit.
I hate to say it but I think Caterham use the same AP one and it might be cheaper.
Heritage must make the parts cheaper too !
Caterham do indeed use the same AP cylinder as Westfield :t-up:
One just come up for sale in Parts for Sale...
Andy
