pincher Posted February 16, 2006 Posted February 16, 2006 Hi, Anybody got a spare set of guages. Fuel, Water temp and Oil press and maybe matching speedo and rev counter ? Not important wether Electrical or mechanical, Standard westfield size ( if that exists ) ta Ian
Guest Posted February 16, 2006 Posted February 16, 2006 I've got an Autometer Sport-comp (black face/silver bezel) mechanical oil pressure gauge that reads from 0-100psi that requires a new capiliary tube, it will fit a hole about 67mm across, also a mechanical water temp gauge as above but reads from 120-240f this one has the tube and the union for fitting the engine, however it won't fit the standard crossflow sensor hole in the head, both gauges are immaculate and only about a year old, maybe of some use to you. pm me if you want more details or are interested
