Weber Alpha Wiring Loom
I need a loom, any condition as long it has all the plugs
Mark
mark
what do you need mate.weber alpha loom for injection or carbs.???
May be able to help out with the IP67 rated plugs if needed
Andy
Loom for Carbs
The ignition only kit NWEBK97017
I won the ECU but the loom has seen better days
i have a weber alpha injection ecu and loom wasted spark spare .but it would be totally different.
Andy
Don't know what IP67 plugs are andy
:durr:
IP refers to an ISO standard for dust and water ingress. IP67 is automotive standard, this keeps contacts clean and moisture free, more than can be said of the dash spade connectors!!!
Andy
