Must have been asked a thousand times before but it is late and I could not find the answer, so apology over.
Simple question, what size (rating) do I need for a 2.0 Zetec on TBs (when I can afford them), intention is to use conventional type of battery.
Why use a conventional battery? An Odyssey PC625 or PC680 would be perfect for the Zetec.
IIRC, the standard Zetec battery (if it's in the nose) is a motorcycle battery anyway.
I'll see if I can dig up the standard number though. Back in a sec...
Hi Steve,
I have recently got a battery for my 2 ltr Zetec and the Factory gave me the numbers:
12V 45AmpHrs
Crank Output 315
Hope this helps
Kev
Here y'go...
Worth noting that a PC625 will have about double the cranking amps of the standard battery. Good for those hot track day starts after a spin... :0:p:D
I agree, go for the Odyssey, mines been excellent.
Shouldn't this have been put into FAQ  ???  :devil:  :D
Got a PC 680 on mine.Bought direct at Stoneleigh. £70,so if you can wait....
I have a redtop 25.... which should have been an upgrade as with all the problems I have been having with my megasquirt only gives about 30 seconds of crank time... the rest of the time in charging and me cursing the day I bought it...
It will be worth it in the end for the weight saving... :D
I'd suggest going for a standard one and then upgrade to a tiny one later like the odyssey or redtop. A stand one will only cost you about £35 for a delta one anyway... rather than the **cough** 87+vat I paid
Battery size as per kevip6's post
Powervamp will do you a PC625 or 680 for about 60 quid delivered if you quote the Lotus 7 Club deal :0
Thanks for the help guys, will go for the PC625 as recommended, that's the great thing about this club, free advice.
Steve ;)  ;)
Steve ;)  ;)
Speak to Ed at Powervamp...
Tell him the WSCC sent you..
Great company to deal with....  :t-up:  :t-up:
Just bought a 680 from Powervamp, they were very helpful. :t-up:
They told me that the deal was no longer on, but they would be open to negotiation on setting up another deal as 'we' had bought so many batteries from them.  Still gave me a good price when compaired to RRP.  About 70 inc VAT and delivery.   :D  :D  :D
Darren
Apologies for the sort-of hijack, but......
What battery would you suggest for a road use only Pinto? The current one is a Halfrauds HB015 with 335 cracking current and 2 years old.
I'm not sure it is the standard one as it was fitted by the previous owner and he had to get a new tray for it. The car has been sitting on the driveway for many weeks so can't manage enough cracking even when fully charged.
*Any* Westfield will be fine with the batteries mentioned.
FWIW, I run my Cossie on a PC625, and my Vx on a PC680.
Since fitting them, my battery charger has been redundant, and the Optimate conditioner that I bought 3 or 4 years ago remains unopened and unused...
You could try one of these
sbs gel battery
I run this exact battery with mt 2.0 xe and no problems atall
£40 its a steal
