James Posted January 14, 2006 Posted January 14, 2006 I would have to agree post him the batery its the simple answer BUT be aware martin if this is a heart monitor most of them have two parts the watch and another section that should be worn to pick up the heart beat if it is this type both need to have battery's there probably lithium and will cost you £5.00 each (if its more than this let me know and ill get one for you cos your being ripped off! one other thing when the chap fits it in the watch tell him to be carefull (These things normally fall apart! and NOT to hold the cell between his fingers as this can drain the power out instantly use tissue paper instead. Goodluck Quote
Buzz Billsberry Posted January 14, 2006 Posted January 14, 2006 Yep just post the battery, if its costing little to sort it then it just helps to put a bit of respect and trust back into people Buzz Quote
Bean Posted January 14, 2006 Posted January 14, 2006 You sure the battery is duff? His heart could of stopped Quote
Nick PC Posted January 14, 2006 Posted January 14, 2006 Are you sure that he has got a heart causing this much hassle! Quote
