Clear Side Indicators ?
Looking for clear-side indicators - someone mentioned Corsa or Astra to be before, cant find anything in a search. Any ideas ?
Tom
Just pop to Halfrauds - a dazzling array of side repeaters in most stores :t-up:
Got my side repeaters from local car shop same ford fittting as the factory ones, got front indicators from SVC.
Car went through sva with these fitted fronts are E marked but side ones where not but the tester never looked.
Cheers lads, was looking at some on flea-bay and wasnt sure of the fitment, I'll check the local places and see what's on offer.
Hmm, less than a fiver on ebay ..
4QQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/Vauxhal....iewItem
Got mine from S-V-C. The side repeaters just have a flat base and cylinder coming out and is fixed by a double-sided adhesive oval pad, so no need to worry about clipping it in, though I do have a cable tie around the inside of mine to make sure it doesn't come off.
Kev.
I bought mine in Motor World.  7.50 per pair!!
The fronts are Landrover - 3.98 a pair plus the yellow bulbs
Regards, John
