O/T Saab 9000 wont rev
Folks,
I've got an old '89 Saab 9000 2.0 16v, it'll start and idle - but it wont rev. If you rev it, it wants to stall and die.
Checked all pipes etc around throttle body, vacuum pipes etc, cant find anything out of place. Have swapped throttle body from a scrappy car to try and rule out throttle position sensor, but no joy.
Throttle position sensor is old swtich type rather than pot, so no adjustment on it. Tried bunging up various piping, if you raise throttle really slow you can rev a very small amount, but will eventually stutter and stall.
Was hoping to get it running for a fun handicap Autotest in a quarry on Monday, but it's not looking good.
Any ideas ???
Tom
Sounds like a lack of fuel, do you know what the fuel pressure's like?
You didn't put diesel in it did you :D
No, but it has been sat up for 2 yrs, so god knows what's livinig in the tank.
try clamping off the return on the fuel rail (if its not one of those crap solid pipes), that should give it some more pressure, then try revving :) if it's not been run for 2yrs theres a good possibility the fuel filters blocked
Is the fuel old? It does go off and you're lucky it would start at all if it is 2 years old.
I agree. Fresh fuel is the first thing to try...
Thirded. Drain the tank before going anywhere else.
It's a long shot but also very possible.....does your sabb have a catalytic coverter fitted, if so they are prone to melting and completely blocking the exhaust. I have seen this many times and the symptoms match exactly. It may be a bit easier to eliminate this than draining the tank?
HTH
Merry Xmas and all that
Si
:xmas:
Also, MAP sensor or MAF sensor if fitted. Try the easier things first though.
Kevin
Another possibility if it has bee sat for a long time is the air flow meter......
if i thinks of anything else I'll scribble them down......
While i am at work      :(
HTH
Si
