The rack supplied to me from westfield is 2.2 turns lock to lock which was invoiced as a quick rack.
Peter
All this 2.8/2.5./2.4/2.2/1.9 is a little meaning less it is how much rack travel you get from one 360 deg turn of the pinion [steering wheel]
So to start you off a Quafe 2.2 moves 62mm each 360 deg turn
can the rest of you with the other ratios fill in the rest thanks and we can see who is steering who a stray
When i can brave the cold i will go and measure my rack travel.
I put a Peter lloyd rallying 2.4 quick rack in my car this year and no lock stops.I find the headlights are in the way,more than the bodywork.I am putting mini headlights on this winter to help cure it a bit.The rack is so much better weighted than a standard rack and wish I had done it first after I bought the car.If you are really that worried about touching the body,I have put some clear plastic on the touch points.This is cheaper than rack stops,you will get the most lock poss, and is invisible from 3 feet,if you know its there.Quick rack every time.
Thanks Mark/Blatman
Now I've just got to decide which wide track to fit :bangshead:
I like the look of the gts and Raceleda set ups but need to know  will need to replace the front shocks springs for longer ones?
Don't really want to do this as i have recently fitted a set of nitrons :love:
I know the cat arms have raised shock mounts so you can use standard length dampers.
Danny
I dont know how the gts is , but with the Raceleda Widetrack you can use your damper . You might need to fit other springs though
Pic on Raceleda widetrack
Niklas Libell
Megabusa
Sweden
so from my thred do i buy a 2.4 rack from westfield or keep my origional mk2 escort one????
2.4 rack every time...
thanks to all enjoyed the discussion thanks to blatman i now have the answer that wanted.
Quafe 2.2 moves the rack 62mm to each 360 deg turn of the pinion
The 2.5 rack that I have just removed moves the rack 52mm per 360 deg turn of the pinion
So come on lets have the other ratios filled in
Just checked my Peter lloyd rallying 2.4 and works out at at about 52mm in travel.I wonder if that makes any difference with the car 18 inches off the ground and the rack dropping down with the suspension.
