Toggle switches best way to connect wiring
Sounds like an earth problem, but it could be a lighting circuit incomplete problem. I have no experience with a Digi-Dash though so for all I know it the dingleflapper not earthing to the reticulating splunge grommet...
hmmmm
thats only on the Mark1 dash
If you dont have the later model with the upgraded dingleflapper then the thermal spectrum phase discriminator calibrator will need the firmware updating.
alternatively
Delicate adjustment of the flapper control contacts, using a suitable manchester spanner (tune for maximum smoke ) may give a temporary solution .
hth.
the digidash I have is the mk1, but you have lost me with the dingle dangle flange flapper thingy
Are you taking the micky? ???????????????
Your both going over my head ??????
Sorry
I Hoped we were not going to deep into jargon for you fella
top and bottom of it is we struggle for a suitable solution at times here and rather than admit we dont reall have an instant reply , we make one up that sounds erm , plausible ?
we often get carried away
or should be  :t-up:
Back on track with the lights
The westfields set up doesn't work like a tin top when it comes to 'some' of the wiring , this is because the body being fiberglass cannot be used for part of the wiring as on a yer tin top !
because of this the -ve return side of the lighting circuit is hard wired in places to make the connection complete .
what this means is that things wont work properly till the rest of the lighting is connectd to the loom and properly wired .
when its all together then you will be better able to fault trace .
that was my thinking, muchos.
Back out in the garage tonight to see if i can get the rest hooked up :D:D
Cheers guys
