Differential
Can someone explain to me the parts of a differntial including LSD type and the various options one has to rebuild one.
I am especially interested in which parts, say a Quaife aftermarket diff replace?
This any use? ???
Andy
As I understand it - the quaiffe option will involve using only your diff case, crown wheel and pinion.  You may be able to reuse the bearings and seals depending on their condition.  You will need quaiffe stub shafts as the Ford ones won't stay in properly.  In a Ford setup they are held in with circlips,  the quaiffe ones use some other method and add about £200 on top of the cost of the diff unit itself.
Mike
This any use? ???
Andy
Yes, cheers, a very useful site also.
Mike
Not sure I know what a stub shaft is but isn;t the ford output drives on the diff 100mm with torx type bolts anyway?
i have fitted the quaif lsd in to many seirra diffs & depending on the age of the casing it is possible that you will have to grind out the sides of the casing to get it in this is no real problem except that you will have to remove all the bearings & steam clean it afterwards, so if you do not have the proper tools it will be very difficult.The ford multi plate is basically not reclaimable after it is worn F.F.developments will do it but it costs a bomb if you do decide to fit an L.S.D. contact me as i have the tools regards Gordon :blues:
This any use? ???
Andy
Great site Andy, very useful, cheers m8
Ecellent site - added to my favourites
Hard boiled egg  :D  :D  :D
in case it helps, here are a couple of pics of the inside of a diff.
1st shows the ATB with crownwheel fitted (housing is on the bench behind).
Second shows it assembled in the housing.
This is for a live axle rather than the independant I think you have but the principle is the same.
atb and crownwheel
assembled.
wouldn't bother trying to recon/build your own diff; leave to the experts with specialist tools etc.
