Latest PPC mag
Just got my latest copy and saw a familiar looking blue Westie in the Walkers Workshop write up  ;)
John
Yep I spotted it as well ;)
That will be mine then ;) ...still trying to get a copy of the magazine though :(
Great day mapping,Dave seemed well pleased with the results from the standard xe,engine is now much smoother,good hot/cold start and no more popping and banging from the zorst.
How does the graph look to you guy`s,coz i wouldn`t know a good looking graph if it turned round and bit me on the :arse:
Graham
Graham
Re-fresh my memory, weren't you local to the cambs area?
Edited to add: The graph looks almost to good to be true, that is one hell of a smooth power curve.
Martin
Yes,am close to cambridge/st ives
Graham
Martin
Regarding the graph,I think even Dave couldn`t quite believe it....so he made another run to confirm :D
Just noticed that little step near the top....what`s all that about then ?
Graham
The little step at the top could be almost anything, but I'd have my money on inlet lengths or exhaust lengths being just a nadge off perfect. I wouldn't even give it a second thought though, I don't think I have ever seen a power curve as straight as that.
Job`s a good`un then,money well spent I think.Now all I want is some decent weather and a track.
Oh,and to sort the clonking noise at the back end and some new tyres and maybe change the g/box and a warmer garage and................
Does it ever end?...............(don`t answer that) :D
Graham
Does the graph say that your car is delivering 200bhp from a standard XE? Is that with carbs or throttle bodies?
Phil
201.2 BHP / 7224 1/min(132mph)
163.9 lbft / 5608 1/min
As far as i am aware the engine has standard internals,ARP bolts excepted,tb`s,sbd 4-2-1 manifold and silencer.
Graham
Those are very good figures. Mine is on standard cams, but has other trick bits (ported head, higher compression etc) that get it to around the same figures as you.
Andy
I would consider an accuracy of +/- 10 % to be the norm.
180 is usual for a good std xe.
Phil
Graham
Very impressive! I've just bought the mag, so will have a read up.
Maybe Windy can shed some light on the subject,come on graham,did you do some fetling that you didn`t tell me about ;)
