Quaife SC CR PRO-Gearbox
Quaife alloy cased straight cut close ratio type 9 PRO 5 speed gearbox with standard input shaft.
Ratio's  2.2, 1.69, 1.21, 1:1, 0.93.
This needle roller PRO gearbox is good for 275bhp @ 9000 rpm.
It is alloy cased and has the alloy lid that has the filler port.
It has come from a 2L VX, but would suit any engine upto 2L, I believe, as it has the standard input shaft.
It has just had all new brass syncro baulk rings and 3rd/4th cones.
£950.00 plus p+p (no more than £25).
Location Surrey/South London.
Ian or Richard 07958 520842 or email Iceservicesukltd@aol.com
You have PM
Tigger
... i want it!
:love:
Is there a Q-shift stick with it?
... i want it!
:love:
If your referring to the Quaife ball type gear stick, then YES.
Is second gear defo 1.69? Seems like odd ratio spacing when you graph it, 1.54 would seem a more logical choice  ???
why are you interested fraser ???  :D
Would be if you'd typed 1.69 but you really meant to type 1.54  :D
I will check ratio's just in case.
ian
