It all has to go!!!
Pair Fluke motorsport Carbon (YUM!!!!!;) cycle wings as new, top quality £170***PRICE DROPPED TO £150***
Silver top fuel pump kit under 1000 miles use, boxed with spare filter and all fittings. £45
2 x Westfield upper engine mounts to suit Pinto and one pedistal (lower mount) used, Ideal for SDV or similar. £25
Pair of 7" Chrome Headlights, good condition £60
Westfield Supplied VDO vision guages, Tach (new), Water Temp (new), Fuel (used), Oil Press (used), Amps (used) all come with mountings, oil pressure sender, fuel sender and water temp sender, will also throw in Mechanical speedo (Not VDO) all the used gauges are in good condition. £200 ***PRICE DROPPED TO £175***
Pre-lit (Escort MK2) Brake master cylinder £5
Lucas Mk2 Escort Rear brakes hoes £5
Astrali Steering wheel boss (to suit SVA compliant steering wheel) £5.00
Westfield Handbrake lever sealing pad £5
Aston type fuel filler cap £10
Upper steering column with lock and keys and loom £75
Pair of Cortina Hubs minus bearings and dust caps £10
All parts + post or delivey costs.
WSCC Members have priority.
Will respond in post order.
Chaz.
Messers Stare and Slippy, back at ya.
Chaz.
Nope, just checked again  :arse:  ???  :D
Mr Major Sir, what bits were you after?
I don't seem to have a PM from you after all (mistook you for somebody else :blush: )
Chaz,
PM sent
Hi Chaz,
Are the chrome yellow cycle wings the later type with rolled lips? Oh and are there any mounting holes in them (presume so) and do they have any cracks/crazing etc in em?
Cheers,
Mark.  :t-up:
The Yellow cycle wings are the later SVA compliant rolled edge type.
They have four mounting holes in each to suit the Westfield cycle wing stays.
There is a small crack 3-4mm long from two of the mounting holes but I used Aerotek alloy allen head bolts with 9mm heads which covered the crack.
They are a year and a half old so are in good nick.
Chaz.
Ok thanks Chaz, will get back to you in a day or two.
Cheers,
Mark.
