cashy Posted September 26, 2005 Posted September 26, 2005 After much thought i have decided to sell my project car. Recently completed modifications for track use and ready to go. Fully road legal Spec listed below and some pics: Email: evocash@dsl.pipex.com for more information and pics Car location:Staffordshire F reg 205 GTi Mi16 £3999 ono I WILL NOT STRIP THIS CAR ITS TO BE SOLD COMPLETE Engine: Fully rebuilt alloy block mi16 engine (angled correctly) Twin Weber 45 Carbs Catcams 283 deg cams (Sep 2005) Custom Manifold Peugeot Sport Group N exhaust (Sep 2005) Spooks Components Red Rocker Cover Brand new Oil Pump (Sep 2005) DES Developments Baffled Sump (Sep 2005) New Silkolene Race Spec OIL BHP approx 190 – 200 bhp Drive: 1.6 Gearbox with Quick Shift Linkage and Performance Clutch Recent Fluid Change Suspension: Currently Lowered 30mm Koni Adjustable shocks, Koni Springs Reconditioned 309 rear beam 309 Front wishbones 309 Driveshafts OMP Front Strut Brace Brakes: 280mm disc conversion, braided brake hoses Mintex 1144 Pads all round Wheels and Tyres: Original Reconditioned 1.9 Gti Speedlines, Nearly New TOYO Proxes Spare Set Of 1.9 Gti Wheels with Used Michelin Track Tyres Bodywork: Full Respray in original Silver, Late Type rear lights and front indicators, gti front mudflaps. Bodywork is in very good condition as you can see from pics. The car currently has DES Developments transfers on side which if needed can be removed without ANY damage to paintwork. Interior: New COBRA Imola Lightweight FIA Approved Seats Drivers Seat in GT width, Passenger seat width standard Mounted using Lightweight ALLOY sidemounts NEW Cobra/TRS FIA Approved PRO 5 Point Harness Straps 3” in Red Red carpet still in place, Most interior trim still in place New Oil Temp Guage fitted on Carbon backplate New Electrical Cut out switch fitted New Oil Pressure Guage fitted in dash Rally design Spare Wheel Carrier fitted to boot Red OMP Helmet Nets OMP Full Roll Cage with door bars Standard door cards replaced with Carbon Look Panels Rally Map pouches fitted to both doors Sparco Black Steering wheel MOT till July 2006 Tax till end of 2005 This car was bought in Jan 2005 as my project, I have just calculated what ive spent on it in the last 9 months and I have receipts totalling £4200 which doesn’t include buying the car. I also have receipts from the previous owners totalling £8607 from March 2003!!!! So I can safely say the cars been maintained at no expense spared. The car is in excellent condition and has been professionally maintained by DES Developments in Walsall. I have only used the car to drive to shows, one track day and to and from to the workshop. To be specific I have done five laps of Bruntingthorpe, four sessions round Donnington and Two sessions round Silverstone recently. Total mileage I have covered since January is only 1811 miles!!! As you can tell I simply don’t get much time to use the car, it gets wrapped up and sits in the garage most of the time. I have the car insured with an agreed value due to its value and condition I have just took delivery of a set of Brand new GAZ Coilovers for the car and a ITG Sausage filter for the Carbs. If you require these then the price can be negotiated either supplied or fitted. For further info and pics please email me on evocash@dsl.pipex.com WORK COMPLETED SINCE JANUARY 2005 OMP Roll Cage Fitted (red) Interior partly stripped out, carpet left in and most plastic trim Carbon Look Door Cards with Map Pockets New Oil Pressure Guage New Oil Temp Guage Cut Out Switch Sparco Steering wheel Bought second set of 1.9 Gti Alloys with Michelin track rubber Purchase and Fitting of New COBRA IMOLA FIA SEATS New COBRA/TRS FIA 5 Point Harness Straps Set of four Toyo Proxes Tyres 309 Reconditioned rear beam 309 Wishbones 309 driveshafts DES Developments Baffled Sump and strengthener plate Rally Helmet Nets Rally Designs Spare Wheel carrier Mounted in Boot MOT Till July 06 Engine work Done Sep 2005: Head removed New CATCAMS fitted 283 degree New Piston Rings New Oil Pump Optimise Compretion Ratio New Crank end seals Valve stem seals, Hone Liners, Exhaust Valve Grind Valve seats New Head Gasket New Head Bolts New Race Spec Silkolene Oil and filter OMP group N exhaust (sprayed with heat resistant paint before fitting) I am in no rush to sell the car but am advertising it since it simply doesn’t get used enough, it spends 90 percent of its time wrapped up in the garage taking up valuable space. I am also starting a new career next month which will take up nearly all of my spare time for the next 12 months. email me: evocash@dsl.pipex.com
