pincher Posted September 24, 2005 Posted September 24, 2005 Hello chaps. I am now preparing for my first track day (Donnington 16 oct) and I understand its a 98 db(a)noise limit. The rules say it should be tested from 0.5 meters away at 45 degrees at 2/3 of max revs. What am I going to claim is this rev range ? I have 98 decibels @ 3300 revs. Is this going to allow me on the track in my 1700 crossflow? If not, whats my best course of action ? cheers Ian. Quote
conibear Posted September 24, 2005 Posted September 24, 2005 You will probably get tested somewhere between 4500-5500rpm Unfortunately, you will need a track friendly silencer, like 6.5" or 7" in diameter and as long as you can physically fit. Once you achieve that then you need to consider driveby levels and induction. Sorry for the bad news Quote
pistonbroke Posted September 24, 2005 Posted September 24, 2005 AFAIK If you somehow get past the static test and allowed on trackthere is a trackside noisemeter will pick yer row up and you get sent off for the early bath If that happens you lose yer dosh too Quote
pincher Posted September 24, 2005 Author Posted September 24, 2005 You will probably get tested somewhere between 4500-5500rpm Unfortunately, you will need a track friendly silencer, like 6.5" or 7" in diameter and as long as you can physically fit. Once you achieve that then you need to consider driveby levels and induction. Sorry for the bad news Is that the 2/3 revs.? Quote
Man On The Clapham Omnibus Posted September 24, 2005 Posted September 24, 2005 4,500 is 3/4 of 6,000 (or 2/3 of 6,750). The former is the norm at some tracks at least. Quote
Mark Stanton Posted September 24, 2005 Posted September 24, 2005 The drive by noise test at Donington can be quite strict earlier this year there were quite a few sevenesque kits that got thrown off Quote
Man On The Clapham Omnibus Posted September 24, 2005 Posted September 24, 2005 If you know where the drive by tester is can you anticipate it and back off a tad? Better than forfeiting your dosh. Quote
adhawkins Posted September 25, 2005 Posted September 25, 2005 If you know where the drive by tester is can you anticipate it and back off a tad? Better than forfeiting your dosh. Ummm...going on a track day and then lifting off every lap sounds like you're missing out on the whole point of a track day. Safer to cancel (and presumably get some sort of refund) until you're sure you can pass. Andy Quote
pincher Posted September 25, 2005 Author Posted September 25, 2005 I've got a couple of weeks to get it sorted and there's a lot of options, going to try longer, reversable silencer first. thanks for all your help. Ian. Quote
pistonbroke Posted September 25, 2005 Posted September 25, 2005 What exhaust you runnin ? Is it a re pack jobby ? Quote
pincher Posted September 28, 2005 Author Posted September 28, 2005 It will be from friday, 22"x5" from Deemon tweeks.Hope it works, actually,I hope it fits. My old one is probly as old as the car (91) but is 24"x4".Other problem is 103db(a) of induction noise at air intake, Got to make a cover over carbs. Ian Quote
pistonbroke Posted September 28, 2005 Posted September 28, 2005 It will be from friday, 22"x5" from Deemon tweeks.Hope it works, actually,I hope it fits. My old one is probly as old as the car (91) but is 24"x4".Other problem is 103db(a) of induction noise at air intake, Got to make a cover over carbs. Ian make sure you pack it with the correct fiber stuff it makes a big difference IMO Quote
pincher Posted September 28, 2005 Author Posted September 28, 2005 I'm hoping it comes with the correct fibre stuff. Mmmmm. food for thought. b******* now I have pre-empted setbacks.Ian. Quote
felters Posted September 29, 2005 Posted September 29, 2005 Sorry to p*** on your chips but I'd be surprised if you got a xflow to 98db with your new can. My maths are crap so I can't figure out the volume of your new silencer but I'd have thought you'd need something bigger and longer to get a xflow down to 98db... Raceline, Raceco, Wunoff are people to speak to. Co-incidentally I'm doing Goodwood today - again - and have a Raceline silencer. 30" long, 7.25" diameter and yes it did involve new headers and chopping the rear wing to get it in, but it's the only way to be sure. Quote
Toby Mack Posted September 29, 2005 Posted September 29, 2005 my can is 5" by around 22" and just gets by xflow below the 98 limit, but it does need to be repacked quite often to achieve this. You might well be ok, although a larger one would certainly be a better bet. Quote
