Blacktop zetec to type 9 gearbox.
I was just wondering if anyone had done this and therefore had any info that i need to know so that i dont mess it up.
Hopefully somone can help so i can get my engine in this weekend.
Sam
Never done one of the Black ones, but in theory it should be the same as the earlier Silver ones.
You will need a spigot bearing, I've the ford part number at home, and a Ointo Clutch I think, but again could find part numbers at home this evening. Clutch arm and releas bearing were Standard Sierra affairs/Westfirld parts, Guess what, I even have the part numbers for these at home.
My CVH starter motor was fine, as was the Westfield clutch cable.
Went in fine, and just bolted together.
Mark
If u could supply those part numbers then that would be very helpful.
btw nice job on that westy in the pic!!  :bangshead:
What chasis is this going in Sam? If it is a type 9 chassis then you will also need a remote filter as the engine will be further forward than in the later mt75 chassis. If it is the later you also have to cut off the bulge for the starter, all but about 2 inch at the engine end. Then the engine and box will go right back in the chassis with no need for a gear stick extension. Robc could email you some photographs of his in place.
jeff
Thanks for the reply, i have actually seen Rob's car a few times so i hope he will give me a hand with cutting the bell housing. I am more worried about the bits that have to go inside the thing. I have found a section that helps on zetecinside.com but i was just seeing if anyone had any hands on knowledge.
:t-up:
Sam you have no hope of Rob helping as it was me who cut his for him. You must be near Bristol / Bath so no problem for you to bring it over and I will do it for you when you are ready. If you pm Rob he has all the part numbers for the clutch, IIRC it is a 1.8 mondeo with a release bearing from an 1.8 sierra cvh.
Jeff
:p
If I'd done mine there would have been no bellhousing left :D:D
i'll email you pics sam :):)
MS test this weekend, finger crossed :cool:
At least this time it won't take 2 hours :D:D:D:D:D:D:D
10mins tops :D:D
Sam, do you have broadband?
Here you go sam.
Pic1
PIC2
PIC3
PIC4
Sorry Sam, just returned from a Europe trip, so I'll look out the part numbers tonight for you.
All the best,
Mark
Dear Sam,
Sorry for slow responce, try these part numbers, for a 1.8 but should be OK for 2L.
fin = Ford identification number
Westfield = their part number
Q'Hazel = Patern part number.
Flywheel, 1.8 fin 1034879, westfield 1761021
Flywheel bolts x6, fin6952658, westfield 1766002
Crank Spigot, fin 1596468, westfield 3243002
Clutch kit 1.8, fin 5028341, westfield 3240019
(plate - 93 BG-7550-AA)
(Cover - 93 BG-7563-AA)
Release Bearing, Q'Hazel CCT 133, Westfield 3243005
Clutch arm, fin 1492706 (71BB-7541-KA), westfield 3248029
Also have recorded for a 2L, Clutch Kit, escort Zetec low lift, fin 5029603, release bearing and spigot the same as above.
All the best,
MArk
10mins tops :D:D
Yes but the two hours was to put it in once, find out westfield had not explained it to you right, take it back out cut the bellhousing and refit engine and box. This was all done with a hot waterbottle strapped to my back because of the slipped disc I have, so pretty good really :t-up: but yes 10 mins max with the angle grinder now we know :D
