/**Temp probs**\
Iv just put another XE lump in my westy. iv taken all sensors from the old engine (water temp etc)
Its all up and running but im having water temp problems or water temp gauge problems
Before (old engine) it read a constant 90deg now it reads just under 90 on idle and between 75/80deg when driving
iv used 50/50 mix of antifreeze
differences from old engine are
piper cams
Alfa ignition system
has anyone any ideas ?
Maybe the new engine has less fur in the cooling system than the old one...
Maybe the sensor has a better earth in the new engine...
Maybe you had a bit of an airlock in the old engine that you have inadvertently fixed...
