3.9 litre V8 Westfield SEIW
Built & registered in 1996. Just 5800 miles.
Chrome yellow exterior with black screen/suspension/roll bar. Carbon fibre dash & Momo gear knob. Lightweight Westfield racing seats. Willans 4 point harnesses. Racing steering wheel.
New short engine in 1998 – 3.9 V8 sourced from Morgan. Dyno’d at 226 BHP. Holley 390cfm carb, Offenheuser 4 barrel inlet manifold, Mallory distributor, 14” K&N filter. 4-1 tubular exhaust manifolds into side exit exhausts.
Gearbox rebuilt in 2000. 3.62 Limited Slip Diff.
7x15 TSW Hockenheim wheels, running Yokohama A510 fronts & A539 rears. Mintex MGB633/M1144 pads.
New in 2004 - springs & poly bushed AVO 22 position adjustable dampers front and rear from CAT Motorsport.
Large capacity fuel tank. Lockable boot box. Detachable rear arches with carbon fibre protectors. Heater. Sigma SG40 Thatcham approved immobiliser. Unoplas side air deflectors.
Insurance just £220/year. All receipts from build & upgrades.
Spares:
3.5 V8 engine block with +20 thou rebore. Assembled with cam, crank, pistons rods & timing chain (all Real Steel supplied) & Viper Hurricane cam.
V8 nosecone
Front & rear Spax & springs.
£9495
Tel 01628 531381 (Buckinghamshire) or 07973  250528
I haven't seen you around - your dialling code puts you no more than 2 or three miles from me - I'm just across the A40 near the King's Head (Harvester). ???
Good Luck with the sale, wish I could afford it :p
I'm up in Flackwell Heath. So your right, only a couple of miles away.
For some reason the car doesn't like crossing the A40!  ;)
It could be that most of the roads it likes are in the opposite direction.
And thanks. I'll be sad to see it go. But needs must.
