VX2L16V Posted August 25, 2005 Share Posted August 25, 2005 Sooo.... What should I be getting? Clips or Locks for my bonnet?? Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
Terry Everall Posted August 25, 2005 Share Posted August 25, 2005 Clips. Imagine an engine fire and bonnet is locked and you cant get in quickly! Ask Paul Pocklington who had fire at Olivers Mount. Good job he had clips! Quote Link to comment Share on other sites More sharing options...
VX2L16V Posted August 25, 2005 Author Share Posted August 25, 2005 Thanks Terry Quote Link to comment Share on other sites More sharing options...
Ian Podmore Posted August 25, 2005 Share Posted August 25, 2005 I would add that you can get clips with the facility to put a 'pin' though it to stop them coming loose when you don't want them to, but you can still undo them quickly. Quote Link to comment Share on other sites More sharing options...
Bazzer Posted August 25, 2005 Share Posted August 25, 2005 Clips easier to fit and you can see they are unlocked !!! Bazzer Quote Link to comment Share on other sites More sharing options...
JohnCh Posted August 25, 2005 Share Posted August 25, 2005 I am using this fastener/pin combo from Protex . Definitley gives me more piece of mind than the over center catches that came with the car. -John Quote Link to comment Share on other sites More sharing options...
slippy Posted August 25, 2005 Share Posted August 25, 2005 Fastener / Pin Combo for me as well Quote Link to comment Share on other sites More sharing options...
geofff Posted August 25, 2005 Share Posted August 25, 2005 Hi, SVA friendly or not? Ta Geoff Quote Link to comment Share on other sites More sharing options...
VX2L16V Posted August 25, 2005 Author Share Posted August 25, 2005 sva ok it has to be Quote Link to comment Share on other sites More sharing options...
geofff Posted August 25, 2005 Share Posted August 25, 2005 Hi Paul, In that case I thought you had to have a lock of some sort for SVA - like the WF kits at the moment. I may be wrong though! Ta Geoff Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted August 25, 2005 Share Posted August 25, 2005 Hi Paul, In that case I thought you had to have a lock of some sort for SVA - like the WF kits at the moment. I may be wrong though! Ta Geoff No, catches (plus covers) were fine, for my SVA at least Quote Link to comment Share on other sites More sharing options...
Flappa Posted August 25, 2005 Share Posted August 25, 2005 Locks on my first car (factory built originally) - right pain in the Latches this time around - so far it's all the way HTH Quote Link to comment Share on other sites More sharing options...
VX2L16V Posted August 25, 2005 Author Share Posted August 25, 2005 Sounds like catches are the way to go then! Cheers for clearing that up!! Quote Link to comment Share on other sites More sharing options...
mark.anson Posted August 25, 2005 Share Posted August 25, 2005 sva ok it has to be My car failed SVA on the factory supplied over centre catches, even though I had fitted the so called SVA covers. The tester said the covers were a temporary fixing and in any case he could still feel the edge through them. Builders supplies do an overcentre catch which has a rubber cover. Mine passed the re test with these fitted. Hope this helps Mark Quote Link to comment Share on other sites More sharing options...
Chasmon Posted August 25, 2005 Share Posted August 25, 2005 Car Builder Solutions do a SVA friendly over centre bonnet catch. Not sure whether you can lock it with a pin though... ***They do look a bit cheesey though Click*** Quote Link to comment Share on other sites More sharing options...
