Bazzer Posted August 7, 2005 Posted August 7, 2005 Hi Good to see you on Friday Mark. Sorry I did not have more time to chat. Was pretty ocupied with shaking down the MegaBooster. For all those interested the car went well. I was limiting myself to 5psi of boost and 6K rpm. Once I was happy things were OK and I stopped looking at the gauges the car went really well felt really strong going up the hill to Radar. I was mapping the megasquirt fueling with an Inovate LC-1 from Bill. What a fantastic peice of kit. I went from the car nearly dying from over fueling as soon as it came on boost, to turbine like smooth within about 5 runs with data logging. I was logging each session then putting the log through a program that calculates a new map based on the wideband reading and your desired AFR. Its running really quite nicely now. cant wait to finnish running and so I can use the full 10.5K revs and 14psi of boost. I was really amazed at how easy it was to map on the track using the wideband. It was a fantastic day right up until the point of the accident after lunch. The two chaps in the Caterham were in our hotel and are top guys and I hope that everything works out for the best. My thoughts are with them !!!!! Cheers Bazzer Quote
conibear Posted August 7, 2005 Posted August 7, 2005 Baz, What hotel is that, how much per night, how far from track, food, bar??/ etc.. Ian Quote
Bazzer Posted August 7, 2005 Author Posted August 7, 2005 Hi Ian This is the Hotel great place the owners are real friendly and enough parking for 3 or 4 trailers. Prices are on the web site. Good food and quiet but nice bar. About 15 minutes from circuit. Cheers Bazzer Quote
CarlR Posted August 7, 2005 Posted August 7, 2005 Baz, Glad to hear it went well, is that Bill Shurvington that supplied the extra bits ? Carl Quote
Bazzer Posted August 7, 2005 Author Posted August 7, 2005 Yep wideband was from Bill. You will be able to use yours though. You can configure the software I used for a TechEdge !!! I was going to email you on Monday to say hi, let you know how it went and to say we missed you mate !!! Give me a call or drop me a line. The tunning with the Wideband/Megasquirt was loads easier than I was expecting. The map is not perfect yet and I have only mapped upto 5psi and 6K revs but it get better with every iteration :-) Cheers Bazzer Quote
bill shurvinton Posted August 7, 2005 Posted August 7, 2005 The tunning with the Wideband/Megasquirt was loads easier than I was expecting. Oh Ye of little faith Seriously though I'm glad its all working as it should. Quote
Bazzer Posted August 7, 2005 Author Posted August 7, 2005 The tunning with the Wideband/Megasquirt was loads easier than I was expecting. Oh Ye of little faith Seriously though I'm glad its all working as it should. It was really that easy. I guess the fact that it starts on the standard ECU and the Megasquirt is only used to supplement the fuel system on boost, makes it slightyl easier. But still it is working and working really well. I got quite hung up on having a decent initial map. In fact it really didn't matter as after a few iterations it was quite driveable. Once I have the full boost range and rev range mapped. It will be time to start playing with the Megasquirt Extra boost control :-) I had a problem with the off boost fueling to start with and the wideband made it quite easy to diagnose and was a good way of testing the fix afterwards. And to top it off the display looks really bling too ;-) Cheers Bazzer Quote
CarlR Posted August 7, 2005 Posted August 7, 2005 You will be able to use yours though. You can configure the software I used for a TechEdge !!! I can use it for Techedge and Megasquirt combo ? or can't ? Carl Quote
Bazzer Posted August 7, 2005 Author Posted August 7, 2005 You will be able to use yours though. You can configure the software I used for a TechEdge !!! I can use it for Techedge and Megasquirt combo ? or can't ? Carl You can use yours :-) Quote
bill shurvinton Posted August 7, 2005 Posted August 7, 2005 Megasquirt supports both techedge and innovate (and a few others) natively. Just set the right line in the ini files and off it goes. Quote
Bazzer Posted August 7, 2005 Author Posted August 7, 2005 This is the Software I used to tweak the map. Seems to work really well. Bazzer Quote
