Mike Lloyd Posted July 19, 2005 Share Posted July 19, 2005 Just tried mounting the Diff as per the westfield build manual, unfortunately the holes in the top of the casing for the long stud appear to be blind (threaded), and so the stud cant be drifted through, anyoune else had this problem? Oh yes, its a Sierra diff from a 92 GLS ( 7 1/2" i think). Any advice appreciated Quote Link to comment Share on other sites More sharing options...
deano.1 Posted July 19, 2005 Share Posted July 19, 2005 Some diffs have the long shaft that passes through casing and some have a bolt either side, sounds like you have the one with bolt either side! Hope this helps Quote Link to comment Share on other sites More sharing options...
Ted Posted July 19, 2005 Share Posted July 19, 2005 I was confused by this but after a few choice words that made SWMBO leave the garage I noticed my manual had a hand-written amendment on the picture saying it could either be the one long bolt or 2 short bolts. TED Quote Link to comment Share on other sites More sharing options...
MAT1800 Posted July 20, 2005 Share Posted July 20, 2005 Hi, I could be wrong... But from what I remember, and it was a while ago now, I had a long stud through the bottom of the diff, and two bolts into the top. Just don't spend 2 hrs struggleing to fit the bottom stud in, only to realise the washers your trying to use are too small for the stud to pass through. Quote Link to comment Share on other sites More sharing options...
geelhoed Posted July 20, 2005 Share Posted July 20, 2005 and so the stud cant be drifted through, anyoune else had this problem? Yup, watch Mark Evans build a sportscar! Quote Link to comment Share on other sites More sharing options...
Eccentric_Rich Posted July 20, 2005 Share Posted July 20, 2005 You've got two options. 1) Use bolts. 2) Drill out the threads and use the long stud. I went for option 2. Richard. Quote Link to comment Share on other sites More sharing options...
Mike Lloyd Posted July 20, 2005 Author Share Posted July 20, 2005 Thanks. Will try again tonight Quote Link to comment Share on other sites More sharing options...
