johnsubaru Posted July 19, 2005 Share Posted July 19, 2005 Hello Can you guys tell me whereabouts your fuel regulator (Filter King) is mounted??? I am sure i have seen them mounted on the scuttle in the past but mine seems really flimsey in the middle and it is quite an heavy unit especially when it will be full of fuel. Thanks John Quote Link to comment Share on other sites More sharing options...
sedsy Posted July 19, 2005 Share Posted July 19, 2005 I put mine at the front end of car just past the carbs on the angled part of the chassis. Quote Link to comment Share on other sites More sharing options...
Greenstreak-Andy D Posted July 20, 2005 Share Posted July 20, 2005 I put mine just ahead of where the steering shaft comes from the bulkhead, captive nuts into underside of chassis rail, can adjust pressure from top, keep the length of hose short between regulator outlet and carb inlet was the advice i was given Andy Quote Link to comment Share on other sites More sharing options...
Blatman Posted July 20, 2005 Share Posted July 20, 2005 Mine's on the scuttle. IIRC, Prepfab, a supplier of Escort rally bits, make a mount for filter kings which looks like it would filt nicely on the scuttle... Quote Link to comment Share on other sites More sharing options...
sportstergray Posted July 20, 2005 Share Posted July 20, 2005 I fitted mine on the center of the scuttle with the angled braket supplied, as shown Quote Link to comment Share on other sites More sharing options...
