Rear wheel stud length
Are the rear hubs on the Madness from Mondeo or what?
Sierra I would have thought? ???
Andy
ALL Ford 4 stud fittings are the same PCD and centre bore size, so it won't matter what model you choose when selecting spacers, as long as it's 4/108. That's 4 studs, 108mm PCD, and IIRC the hub register is 67.4mm (or is it 64.7mm?).
So Mondeo/Sierra/Ka/Focus/Escort will be fine...
Spacers from Hub-Centric link above are the same for Sierra, Mondeo etc anyway - so I'll probably go for these and keep the stud length and closed huts.
Tony
Thanks Blatman - that response was verging on anorak status!  I should know Mondeo has 5 studs - just like the Jag X-type I helped design for 3 years!!!!!!
Tony
Er, Modeo's are 4 stud. Well, mine is at least...
Check out later ones - Ford changed to 5 stud because Jag wouldn't accept 4!
There's a nice little fact to stash away ;)
