Rear wheel bearing for Megabusa
Hi
How easy is it to inspect/repack or replace a rear wheel bearing on a factory Megabusa?
The car has Westifield alloy hubs and each has a very large lock nut holding the hub on.
Do I assume the brakes disc needs to be removed also?
Can the lock nut be reused? or is it best to buy a new set from Westfield? (or other?)
Also what's the torque setting for the nut?
Where can I get new bearings from? are they standard Ford ones? or do I get them from Westfield?
Finally is any special grease needed for the bearings?
Thanks in advance
Rob
REAR W.B. QWB 422 £19.50 (SKF-633295B)
its a sealed bearing and will come with a new nut
you need to take the upright off to press the bearing out
