CD Burning Software
Just finally given up trying to make sense of Nero = I'm scrapping more discs than I'm writing
Can anyone recommend CD Burning Software for the over 40s
Ah, was gonna suggest Nero when I saw the title.
What problem are you having? ???
Andy
Roxio Easy CD Creator  :D might be worth a try  :D
Andy
I am certain I am following all of the correct steps.
The main problem is with ;
a) Photos - 50% of time open as unreadbale files not jpgs which they are dragged over as
b) Music (legally) downloaded - ends up as a folder that a CD player can't open instead of individual tracks - I am not doing anything different each time
Chris
chris for burning music i use iTunes its dead simple,very quick and free.google for iTunes and download the xp version.to use it just open a new file and drag and drop the songs you want to burn onto it .insert disc and press burn in the top righthand corner,job done.if you want to copy an album just import it onto iTunes and burn it the same way.dead easy
In nero are you using the wizard?
I don't use the wizard myself but it may help.To make an audio cd i simply select the "make audio cd" option and drag the songs in to the window, then hit burn.Never failed yet.
For things like pictures, i guess it depends what you are trying to do.If i wanted to just add pictures or say a mixed backup disc (mp3's, txt's, pics etc etc) i just select the "make data disc" option and drag in what i like then burn.
What media are you using by the way and what cd/dvd writer?
I thought It was only me having trouble with Nero .
Seems there are different versions  freeware ? or payed up front jobbies ?
The Nero I got with my DVD RW is next to useless afaics Theres an option to  upgrade for  x pounds but I wouldn't be happy  if I spent good money on what I see is a chronically sick programme .
I wanted to save loads of jpeg pics but couldnt get the thing to write  as the files are Too Big ? yet the files are well inside CD rom memory sizes
And I get even less success  with video files ,
I have been blaming it all on "operator error"  and am awaiting devine intervention from above .
I thought Nero was supposed to be the dogs goonads
yours
disillusioned    :arse:  :arse:  :arse:  :arse:
I'm happy to send out the version i have on CD to anyone if it helps.Never had a problem with it, just PM me an address.
I find Nero burns OK, but opening files on a CDRW can be problematic. CDR's seem to work fine though. For instance, if I burn a CDRW with some pictures, the CD drives at work (Win2000) can't open them. The disc looks blank in Windows explorer. Same deal goes for getting prints done at Jessops/Boots/Tescos. CDRW's don't work, CDR's are fine...
Any version of Nero other than 6.0 onwards, struggles under XP home or Pro. Can't find any driver upgrades either  :devil:
Nero 6 & Nero 6 with Suite - both OEM - are available on ebuyer. Postage is a big of an  :arse:  but if yer looking at getting another shiny toy at the same time it'll be ok
Nero v6 £1.40 inc vat
Nero v6 inc suite 3 (DVD) £5.63 inc vat
Works fer me...
Toast - makes CD burning a breeze
but
you'll need a proper computer to use it
although
same people make Easy Media Creator for those funny old PC things, so probably works as well
Toast sounds good - I burn toast every time.
Thanks for all of the advice - I'll let yous know how I get on
Tried me CD under grill, buttered  wrong bl66dy side  :p
Try Musicmatch Juke Box from Musicmatch.com.  You can get a free cut-down version, I found it so simple and reliable I brought the updates.
