Hi all,
Just a quickie.
How many of you have installed dual circuit brakes, ie on opposite corners?
I have already decided to route my brake lines inside the tunnel not wanting to tempt fate. But it seems slightly odd to me not to have a safer system as standard.
C
I assume you mean connecting the LF to the RR, and vice-versa?
On a Westfield, you should connect both fronts to the *rear* port of the master cylinder, and both rears to the front oport of the master cylinder. No reason to worry about the brakes at all...
My understanding was that on a dual circuit system you have two independant cyclinders on one shaft so if one line gets depressurised you maintain pressure to two wheels.
I thought it was FR with RL and FL with RR, but I could be wrong.
I know the standard system is just front and back off one line each but production cars have featured a failsafe for many years.
The 'split' of the circuits can be diagonal, as you describe, or front/rear split. It is exactly the same fail safe as your average production car, they feature either system as well....
You could go extra crazy and fit twin tandem cylinders !! An individual run for each corner :p
OK I was looking for a serious answer, is it worth fitting a cylinder with a dual supply?
I intend to drive my car slightly differently to how I drive my daily car so I would have thought it was more worthwhile...or am I paranoid?
.or am I paranoid?
No, we are all out to get you.
:p  :p  :p  :p  :p  :p
The internals of a dual circuit master cylinder is effectively two systems. There are even two separate fluid 'compartments' built into the fluid reservoir. If the worst were to happen, the fluid *could completely drain out of one circuit, but it would leave the other side to bring you to a halt, albeit with more pedal travel. A sytem with two master cylinders would behave in exactly the same way if a circuit were to fail too... :t-up:
OK, but that means to ahve this facility I would need something different to the standard tandem brake master, correct? Or does that just split things front and back?
Nope - the standard tandem master cylinder splits front/rear,  and  keeps the circuits totally separate....
OK,  :D
Thats a wait off. I have been miss informed then!
Thanks for the advice!
