Rear Fog Light and Revesing Light
Just putting the reversing light and fog light on the body.  Anyone got any suggestions on how to line the two lamps up so they are as straight as possible with each other?
I've tried to use a line between the two tail lights but it's not very accurate.
I used measurements from the floor to the main light cluster fixing holes to get the height correct then using a length of 3x2 and a spirit level I marked a straight line across the back of car.
TED
:D:D
I ran some masking tape across from one rear light fitting to the other and took measurements from this!
Quite funny for you to commenting on reverse lights Dean...........well I suppose we do use it a lot!!!! :durr:  :D
