Nothing to do with Westy but wondered if any one out there could offer knowledge and advise.
I have a 12v sump pump which will be connected to a 10a/h  deep cycling marine battery. I need a charger that will trickle charge the battery permenently with out zapping it .Anyone suggest a good charger or specialist supplier. The pump will only run in an emergency flood situation.
There must be a better option than Halfrauds.
Cheers Phil
I can get hold of solar chargers if they are any use to you.
I've got a 12v voltage regulator that you can wire into an ordinary battery charger to make it into a trickle charger. £10 Inc postage. I've used one for 2 yrs. v.good
Sounds  interesting.How do they work and will they work all year round.
Phil
