Ted Posted June 19, 2005 Share Posted June 19, 2005 I have just received a new inertia reel seat belt from Westfield but the webbing is fully retracted and won't release. Is there a way to release it so I can use the belt or should I return it to them and obtain a replacement? Thanks TED Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 19, 2005 Share Posted June 19, 2005 Think you need to pull it out slowly with the coil in the correct orientation ( the position it would be in the car ) as the inertia bit is a wieghted cam working on gravity centrigugal force . Otherwise ring the factory they should help you HTH Quote Link to comment Share on other sites More sharing options...
al4carol48 Posted June 21, 2005 Share Posted June 21, 2005 Ted, I hope they haven't given you the reel I sent back a few weeks ago! A brand new reel shouldn't be fully retracted but instead the webbing should be folded up and secured to stop it fully retracting. Both the reels I had got stuck. I got harnesses instead as I couldn't be arsed, they're a lot easier to fit! Quote Link to comment Share on other sites More sharing options...
Ted Posted June 22, 2005 Author Share Posted June 22, 2005 Spoke to Mark, no joy releasing it so took it back and got a new one with webbing folded neatly, in and all sorted. TED Quote Link to comment Share on other sites More sharing options...
