Cellulose Thinners on Gel Coat
I got a huge load of tar on the tub tonight and need to know quickly if its ok to remove it with cellulose thinners or will it mark the gel coat ?
Stevie
Tar comes off GRP lovely with "Bug Wipes" from tesco/Petrol stations
IMHO I wouldnt put cellulose anywhere near it.
hi, i've used cellulose on the GRP of my Westy and it DID NOT damage it at all, if in doudt try it on an inconspicuous part of the car, cheers phil  :p
i find mixing them with a good tonic helps, none of the cheap tescos ownbrand crap, a proper tonic, something that still has quinine in (surprisingly waitrose comes high on my survey) and they will taste loverly
oioi you are on something arn't you ?
Thanks Phil, I did try it on a hidden area, and it came off with ease, but I bricked it in the end in favour of the bug wash - harder going.
The run was worth it though - outstanding 80 miles of twisty country roads then long straights, might organise a local run there. Hope the tyres grip better once the tar hardens - got quite a build up , will have to recalibrate the speedo :D
life
(you did say "in for something" ddint you?)
:D
hope your not serious
you never know ;)  life inside is very comftroble these days, espcially if you only crime is a (french accent required) ponchant for chicken.  of course the other inmates beat me sensless, but hey thats what i pay them for
use the cellulose. its not paint, its gell coat. ;)
I would say definatley NOT
cellulose thinners will dissolve gel coat , might not do any harm on old well cured gel but I would be very wary of long  term effects .
have u tried white spirit ?
whichever you use I would wash off after with plenty of soapy water
Edit to say
Ckikens = quite harmless
male of species loves to show off   :p
WD40 removes it with no effect on the Gel Coat
thinners wont harm gel coat, if it did you wouldnt be able to repaint a westy..
best thing  for removing tar is......Tar and glue remover or in its cheapest form panel wipe  ... the stuff you use to remove waxes/silcones  before painting... or petrol does the same job...
Thanks for all the replies guys, I'll use panel wipe to get thre remainder off
Nobody mentioned good old Lurpak - it's v cheap - look in the fridge. Don't let the angry one catch yer  :D
