SDS Posted June 15, 2005 Share Posted June 15, 2005 Thought it would be a good idea to fit a catch tank to my Zetec 1800 but the tank supplied by Westfields is just too big to fit (factory insist it will). Has anyone sourced a better tank from a different supplier? Quote Link to comment Share on other sites More sharing options...
thos Posted June 15, 2005 Share Posted June 15, 2005 Try one of these: http://www.nfauto.co.uk/oil_catch_tank.htm Quote Link to comment Share on other sites More sharing options...
Major Stare Posted June 15, 2005 Share Posted June 15, 2005 There are loads out there to try. Have a hunt through Demon Tweeks, Burton and do a search on here, its been mentioned before. Theres also a WSCC member who's looked into devolping these.... do a search! I use an aluminium cycle water bottle and cage Quote Link to comment Share on other sites More sharing options...
a4gom Posted June 15, 2005 Share Posted June 15, 2005 Try one of these: http://www.nfauto.co.uk/oil_catch_tank.htm Careful if you intend using it on the track it needs to hold 1L Quote Link to comment Share on other sites More sharing options...
JonnyBoy Posted June 15, 2005 Share Posted June 15, 2005 I used something like this Quote Link to comment Share on other sites More sharing options...
Pembroke Pat Posted June 15, 2005 Share Posted June 15, 2005 Where did they suggest fitting it? Quote Link to comment Share on other sites More sharing options...
Vinny's Westie Posted June 15, 2005 Share Posted June 15, 2005 Make your own and place it on the nearside by the bulkhead/wing. Plenty of space for one of any shape. Quote Link to comment Share on other sites More sharing options...
SDS Posted June 15, 2005 Author Share Posted June 15, 2005 Westfield say that it fits in front of the clutch and brake master cylinders but with the steering shaft and engine mounts also in the way i cannot see how it's supposed to fit??? Quote Link to comment Share on other sites More sharing options...
deano.1 Posted June 15, 2005 Share Posted June 15, 2005 Ive got a W/F one that i havn't fitted yet, i can't see how its suppose to fit either!! anyone got any pics of a Westfield one fitted at all Quote Link to comment Share on other sites More sharing options...
JonnyBoy Posted June 15, 2005 Share Posted June 15, 2005 mine sits above the brake master cyl. riveted to the ally pannel behind the stop go pedals Quote Link to comment Share on other sites More sharing options...
chappers Posted June 16, 2005 Share Posted June 16, 2005 I fitted one of the nfauto large round catch tanks to my 1800 zetec, though I bought it off ebay for ($59 inc.p&p rather than £62), because of the cost saving and also because I could get a silver round one rather than the titanium finish, though mine had 10mm outlets rather than 0.5". A £5 ebay breather filter was also added. Not a good pic but fitted it as below. The tank volume is only 550 ml though, so if you want one for sprinting etc. then it will be too small as 1ltr is the minimum. Still it works fine for me and the sight gauge is still clean so I have never had to empty it. Cheers Kev. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 16, 2005 Share Posted June 16, 2005 seen some sprint guys using old thermos flask with the glass removed . as long as its robust and catches any oil chucked out the breather rather than dumpin it on the track, I dont think it matters much what it looks like. Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted June 16, 2005 Share Posted June 16, 2005 For most trackdays a min 1 litre capacity is required aesthetics is down to owner Comp use also requires 1 litre capacity Quote Link to comment Share on other sites More sharing options...
Bazzer Posted June 16, 2005 Share Posted June 16, 2005 For most trackdays a min 1 litre capacity is required aesthetics is down to owner Comp use also requires 1 litre capacity Which track day organisers have checked your catch tank Mark ? Most trackday companies do no scrutineering at all, because if they do they are concerened about liabilty. As they are basicaly saying the car is fit for track if they passed it. They won't care as long as you are not dropping oil over the track and no one will check. Fiting a 500ml catch tank would not have stopped me from doing any of the Track days I have done. That said mine is about a litre :-) Cheers Bazzer Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted June 16, 2005 Share Posted June 16, 2005 Its not a question of checking By requesting that items be addressed in instructions the onus is then on the driver to ensure his/her car complies If anything untoward happened which as a direct result is contributable to the driver not ensuring his/her car complies then it is the fault of the driver and not the organiser Signed: WSCC Mallory Park Track Day Organiser Quote Link to comment Share on other sites More sharing options...
