m12oly Posted June 13, 2005 Share Posted June 13, 2005 is it reccommend to use sealant on the transmission tunnel panals? i am aware they may have to be removed for inspection Quote Link to comment Share on other sites More sharing options...
Big R Posted June 13, 2005 Share Posted June 13, 2005 Hi - as far as I've seen, normal practice seems to be to seal the side panels and fit the top panels dry. Quote Link to comment Share on other sites More sharing options...
KerryS Posted June 13, 2005 Share Posted June 13, 2005 I used foam sealing strip on the top panels and sealant on the side panels. IIRC the manual says use self-tappers on the top panels but I drilled and tapped M5, others have used rivnuts. Kerry S Quote Link to comment Share on other sites More sharing options...
deano.1 Posted June 14, 2005 Share Posted June 14, 2005 The 5mm pins that come in the kit are self tappers, I know they don't look much like self tappers but they work a treat! Quote Link to comment Share on other sites More sharing options...
