Escort quick rack
Hi all,
Anyone got an Escort quick rack they can sell to me rapidly? There's play in mine, and on track today at Castle Combe it was a bit disconcerting under braking, so I'd rather get it replaced before Curborough (two weeks time).
Drop me a PM or an e-mail.
Andy
  • Replies 33
  • Mark Stanton
    12
  • adhawkins
    12
  • DickieB
    7
  • leighc
    1
They're readily available - is yours a quick rack or standard ??
If standard an exchange unit at most local motor-factors will have you sorted within a couple of days  ;)  ;) replace the mount rubbers (if not solidly mounted) as well while you're down there and take a look at track rod ends - they're just a few quid disposable items  ;)  :D or may end up in "Emergency Spares Box"  :D
Apparently they're not that available, Dickie B is currently waiting for one, due in at the end of the month.
Mine is a quick rack, yes.
Andy
Is this what I'm after? This price seem sensible?
Andy
Excellent - and 2 bolt type rather than 1 large nut. Go for it.
Ok, cool. I'll phone them Monday.
Where do I get the mounts and the track rod ends then? CAT? If some duffer rings up and says 'I want rack mounts and track rod ends' will they know what I'm talking about? :)
Andy
Use the mounts you have now - they will be fine.
As for track rod ends, go to your local motor factors and ask for Quinton part no QR1384S (you'll need 2)
Andy if you get one of those quick racks from peter lloyd can you let me know what you think? I might get one too :)
If you have solid ali mounts then re-use its not a problem  :D  :D
If you have the U shaped standard Ford things they have a rubber insert which is the bit worth replacing  ;)
Simply take a look - if they're shiny you have ali mounts  ;)  :D
Ah, I was cheating, I know Andy has solid ali mounts - hence re-useable!
Has he got front wide track ???
Yes
Good point, he didn't have extensions. Mmmm, will email Andy...
In which case he might need to ring Cat or remove the longer arms from his current rack and swap em over  :D  ;)  ;)  ;)
Which is exactly what I just emailed him with and PM'd him with.  I leave for Moscow tomorrow at 4:50am so will someone please help Andy out!
Whatever the solution, I'll happily fit it on my return (yes, my wife now weekly commutes, so I have b*gger all to do every evening! )
Will wind him up first though - its more fun that way  :D  :D  :D  :D  :devil:  :devil:  :devil:  :D  :devil:  :D
