pinto pete Posted June 11, 2005 Share Posted June 11, 2005 i have an open 3.9 diff, it wines like at cat so i am changing it this weekend. i am replaceing it with a 3.6 lsd out of a 4x4. the 3.9 should be under warnty ? so when i get it back will it be better to refit it or keep the 3.6 lsd Quote Link to comment Share on other sites More sharing options...
Paul Ash Posted June 11, 2005 Share Posted June 11, 2005 Take the lsd out of the 3.6 and put it in the 3.9. So you end up with a 3.9 LSD. This is all of course relavant to set up. i.e engine/g/box/wheels etc. and that they sre both 7" diffs. But 3.6 will give your more top end and less acceleration if 3.9 is what you normally run. Quote Link to comment Share on other sites More sharing options...
pinto pete Posted June 11, 2005 Author Share Posted June 11, 2005 the 3.6 is a 7" the 3.9 is a 7 1/2" will this make a diferance Quote Link to comment Share on other sites More sharing options...
stu999 Posted June 11, 2005 Share Posted June 11, 2005 Yep, you wont be able to use the 3.9 CWP in the 3.6. Also, to fit the 7" diff into a chassis that has had a 7.5" diff fitted, you will need a half inch spacer for the top mount, as well as a long stud, again for the top mount, as opposed to the two bolts that the 7.5 uses... Quote Link to comment Share on other sites More sharing options...
pinto pete Posted June 11, 2005 Author Share Posted June 11, 2005 iv'e got all the studs and spacers came with the kit. i'm gonna open it up to make sure it's clean. is it just normal diff oil for a refill Quote Link to comment Share on other sites More sharing options...
deano.1 Posted June 11, 2005 Share Posted June 11, 2005 Oh and you'll be able to do donuts with the LSD Quote Link to comment Share on other sites More sharing options...
stu999 Posted June 11, 2005 Share Posted June 11, 2005 is it just normal diff oil for a refill Yup, normal diff oil... Quote Link to comment Share on other sites More sharing options...
