Big R Posted June 10, 2005 Share Posted June 10, 2005 as the title asks - any tips for cutting carbon effect plastic sheet ? Is a fine tooth hacksaw the best option ? Quote Link to comment Share on other sites More sharing options...
scott beeland Posted June 10, 2005 Share Posted June 10, 2005 Flat sheet? Stanley knife is great Quote Link to comment Share on other sites More sharing options...
chappers Posted June 10, 2005 Share Posted June 10, 2005 I first tried a jig saw but the front of the blade cut it and it just welded back together with a seam at the back of the blade due to the heat build-up. . Next time I'd try a hack saw blade or sharp knife instead, but after roughly cutting it oversize, the dremel tidied it up very nicely. Quote Link to comment Share on other sites More sharing options...
Blackdog Posted June 10, 2005 Share Posted June 10, 2005 Use a variable speed jigsaw, set it on a slow cut and use a fairly fine blade- this seems to stop it ' hot welding' itself back together again. For any straight cuts use a normal hand saw.Medium to fine sandpaper sees of any irregularities. Quote Link to comment Share on other sites More sharing options...
