scott beeland Posted June 10, 2005 Posted June 10, 2005 Be careful of heavy duty wheel twatting. Ally wheels can fracture if you load 'em up wrong. Get car up in air; grip weheel tyre really tight (bearhug kinda style) and rock it on the hub after a healthy dose of WD40. should come off Quote
Steve L Posted June 14, 2005 Posted June 14, 2005 Well, he said he was going to try on the 10th, and today is the 14th. Does someone want to check his garage and see if he's lying unconsious under his wheel? Quote
Mike H Posted June 14, 2005 Posted June 14, 2005 nunney it harder! Most tyre places have 6ft steel bars just for this kind of thing - like when your main dealer doesn't put any copper grease on your hubs during a service. Mike Quote
moomin Posted June 14, 2005 Posted June 14, 2005 PlusGas is waaaaaaaay better than WD40 in this sort of situation. moomin Quote
Nick A Posted June 14, 2005 Posted June 14, 2005 Big copper/hide mallet does the trick and next time make sure the wheel pushes on so it's flush with the hub by hand If the wheel is tight going onto the hub it probably won't torque up correctly and will work lose in a month or so we get this a lot where i work, people get a knock when cornering a month or so after having tyre fitted and are shocked when you can turn the wheel nuts by hand Quote
S8ight Posted June 14, 2005 Posted June 14, 2005 PlusGas is waaaaaaaay better than WD40 in this sort of situation. moomin if its tight going on its pointless using anything other than a FBH Quote
monkeee Posted June 14, 2005 Posted June 14, 2005 Dont think Steve will be answering for a week He,s on his way to Le mans lucky barsteward Quote
Steve R Posted June 22, 2005 Author Posted June 22, 2005 Sorry to keep you all in suspense Yep, just got back from Le Mans - had a fantastic week. For the record, I did manage to get the wheel off eventually. Used a combination of an overnight soaking in WD40 (the car, not me) then used a large block of hardwood and a steel faced hammer to bash it off. The shock of using the hammer and wooden block was eventually enough to shift it unlike the rubber mallet I tried previously. Thanks for all the "nunney it really hard" advice, much appreciated! Steve. Quote
