Mulford Posted June 8, 2005 Share Posted June 8, 2005 Afternoon all, Does anyone know how to get a nice selection of 2nd gear without making it sound like your killing the box ? Am new to BECs and can't seem to get the knack!!! Cheers Quote Link to comment Share on other sites More sharing options...
adhawkins Posted June 8, 2005 Share Posted June 8, 2005 Press the left hand pedal in? (Sorry, couldn't resist - I'm sure someone will be along with something a little more helpful soon...) Andy Quote Link to comment Share on other sites More sharing options...
scruffythefirst Posted June 8, 2005 Share Posted June 8, 2005 I'm sure someone will be along with something a little more helpful soon... Put a proper engine and box in Quote Link to comment Share on other sites More sharing options...
adhawkins Posted June 8, 2005 Share Posted June 8, 2005 I'm sure someone will be along with something a little more helpful soon... Put a proper engine and box in Ok, so I was wrong Andy Quote Link to comment Share on other sites More sharing options...
scruffythefirst Posted June 8, 2005 Share Posted June 8, 2005 I aim to please Quote Link to comment Share on other sites More sharing options...
JeffC Posted June 8, 2005 Share Posted June 8, 2005 just back off the revs and change without the clutch going up the box, should drop in smooth , if doesnt there may be a problem.... all bec boxes sound as though they are fooooooooooockd so i maybe wouldnt worry toooo much Quote Link to comment Share on other sites More sharing options...
Blatman Posted June 8, 2005 Share Posted June 8, 2005 That's 'cos *all* bike gearboxes are dog boxes. The change from first to second is often noisy (even on a bike) because you have to go through neutral. It's a "double shift" if you like. And yes, clutchless upshifts are possible, but you *are* taking the corners off your dogs when you do it, so don't be under any illusion. Unless you are racing and *need* to save every tenth of a second, then smash through the 'box all you want. If not, use the pedal on the left and *never* do clutchless downshifts... And for the record, my biking experience is 25 years worth and around 900,000 miles, so I know how to use a bike gearbox, and I know how to break one... Quote Link to comment Share on other sites More sharing options...
Kiwi XTR2 Posted June 8, 2005 Share Posted June 8, 2005 If it's anything like the 'busa in my XTR², 1st to 2nd always sounds like dropping a bucket of bolts on the floor if you drop out of 1st from below 6,000rpm. Dropping from above 6,000 it's sweet. Quote Link to comment Share on other sites More sharing options...
Mulford Posted June 9, 2005 Author Share Posted June 9, 2005 Thanks for the feedback guys. Suppose I'll just have to just practice, b*******, shame that, means I'll have to drive it some more...... Quote Link to comment Share on other sites More sharing options...
Renmure Posted June 9, 2005 Share Posted June 9, 2005 but you *are* taking the corners off your dogs when you do it, so don't be under any illusion. Unless you are racing and *need* to save every tenth of a second, then smash through the 'box all you want. If not, use the pedal on the left Bummer. I was almost getting the hang of the clutchless bit. Quote Link to comment Share on other sites More sharing options...
felters Posted June 10, 2005 Share Posted June 10, 2005 Put a proper engine and box in he has... "they all do that sir" I'm afraid. I am fitting a cable change to mine though to replace the rods connecting the gear lever to the box - apparently it helps. I'll report back. Cheers Mike Quote Link to comment Share on other sites More sharing options...
Blatman Posted June 10, 2005 Share Posted June 10, 2005 Might help with the feel, it won't help the noise. It'll still sound like a bag of spanners when you get a "doggy" (not dodgy, doggy) change. You are merely substituting a solid lever system for a flexible lever system. Nowt wrong with that, but it will do nothing to help with what happens inside the box when a couple of gear dogs meet in the middle and have a fight before engaging... Quote Link to comment Share on other sites More sharing options...
Al Yupright Posted June 10, 2005 Share Posted June 10, 2005 Felters, Who told you that a cable would be better? I fear it will be wasted effort. The Westfield linkage is very good... Quote Link to comment Share on other sites More sharing options...
Blatman Posted June 10, 2005 Share Posted June 10, 2005 I wonder if this is happening as a result of it becoming more common knowledge that Porsch GT3's use cables from the gear lever to the 'box? The ususal "if it's good enough for Porsche..." type deal. I'd be careful. The Porsche cables that make their system work are works of push/pull art and not easily replicated, I would have thought... Quote Link to comment Share on other sites More sharing options...
Al Yupright Posted June 10, 2005 Share Posted June 10, 2005 Nah, a lot of BECs use push pull cables. My doubt is in the friction of the cable. The Westy system is all bronze bushed and moves completely freely with no stiction. All the lever lengths just nicely work too. I've heard with cables you can get a certain amount of stiction, especially if you've got any significant bends in it. The lever return spring in the gearbox is very weedy anyway so making it work harder doesnt seem a good idea. Quote Link to comment Share on other sites More sharing options...
