WESTMETAL Posted May 21, 2005 Share Posted May 21, 2005 2.1 Litre Pinto Engine Built by Vulcan Engines, has done 1500 miles been in westfield for 12 months. All parts were brand new when built by Vulcan Engines, as in: New twin 45 side draft carbs New Pistons Rebore Up-rated cam shaft Valves and Springs Up-rated Oil pump New water pump Cut down sump Exhaust system Starter motor and alternator fitted New distriburator and leads Optronic Ignition system with Up-rated coil Comes as complete package, ready to fit in car, the engine is still in my westfield, so it can be heard running and driven. All Reciepts availible and pictures on request Please Ring or email to Dalemetalwork@aol.com or 07747147175 Link to comment Share on other sites More sharing options...
WESTMETAL Posted May 26, 2005 Author Share Posted May 26, 2005 Sold to Liam thank you Dale Link to comment Share on other sites More sharing options...
Martin Keene Posted May 26, 2005 Share Posted May 26, 2005 I feel the phone ringing already... Link to comment Share on other sites More sharing options...
Thrustyjust Posted May 26, 2005 Share Posted May 26, 2005 Bargain engine,I know the phones been ringing this end,to help Dale fit the Duratec.At least I have a few weeks before craning the pinto out. Link to comment Share on other sites More sharing options...
Liam Posted May 28, 2005 Share Posted May 28, 2005 Er, Martin, brrm ding ding ding ding dah daah dding dding.............. Link to comment Share on other sites More sharing options...
Martin Keene Posted May 29, 2005 Share Posted May 29, 2005 Oh Dear, he's not taken the medication again... Link to comment Share on other sites More sharing options...
Liam Posted May 30, 2005 Share Posted May 30, 2005 ......was that lucy..........in the sky..................with diamonds..................... Link to comment Share on other sites More sharing options...
ChrisF Posted May 30, 2005 Share Posted May 30, 2005 Liam Link to comment Share on other sites More sharing options...
Martin Keene Posted May 31, 2005 Share Posted May 31, 2005 He's finally lost it... It's will be the sudden weight reduction of his wallet thats done it! Link to comment Share on other sites More sharing options...
ChrisF Posted May 31, 2005 Share Posted May 31, 2005 He's finally lost it... It's will be the sudden weight reduction of his wallet thats done it! LOL From one boat anchor to another Link to comment Share on other sites More sharing options...
scruffythefirst Posted May 31, 2005 Share Posted May 31, 2005 Bit of a drastic way to solve the oil pressure problem isn't it Link to comment Share on other sites More sharing options...
Martin Keene Posted June 1, 2005 Share Posted June 1, 2005 Your not kidding! Buts he's tried everything else he (and I) can think of. The oil galleries in the block are the only things not to have been changed... Link to comment Share on other sites More sharing options...
scruffythefirst Posted June 1, 2005 Share Posted June 1, 2005 Has he moved the sender to another position? Link to comment Share on other sites More sharing options...
Martin Keene Posted June 1, 2005 Share Posted June 1, 2005 No, but the gauge was replaced with a mechanical one to confirm it wasn't an electrical problem. If the new engine does not show the same syptoms, which I very much doubt it will, then I might borrow Liams old engine and strip it to see if I can find a problem with. Something must be causing it. Link to comment Share on other sites More sharing options...
scruffythefirst Posted June 1, 2005 Share Posted June 1, 2005 I bet you £5 its a minor blockage in the gallery near the sender Link to comment Share on other sites More sharing options...
