Richard Houlgate Posted May 17, 2005 Posted May 17, 2005 This is described as 2.8 sporting close 5 speed Ford gearbox with ratios 0.87, 1.0, 1.26, 1.81, 2.8 Heavy duty This is from BGH Geartech What sort of gear box is it? It has a Burton q/shift gearlever kit. Is it possible to fit a reverse lock on this as it is all too easy to get reverse instead of first. Back axle is Sierra 3.92 Quote
adhawkins Posted May 17, 2005 Posted May 17, 2005 Well, your version certainly sounds better than the standard one. The Type 9 has more scope for upgrades in terms of ratios and the like (and it sounds like yours has been upgraded). Andy Quote
Martin Keene Posted May 17, 2005 Posted May 17, 2005 As Andy said it is a Type 9. Orginate's from a Sierra, but yours is a modified by BGH Geartech with a longer 1st gear. It's called a 2.8 Sporting Close, because BGH base the gearbox on the 2.8 ltr V6 version, not a 4 cylinder version. Not a clue why they base it on v6 'box though... Quote
Muttleys V8 Posted May 17, 2005 Posted May 17, 2005 Very good box to have, mine cost me £1K from BGH a couple of months ago, very happy............ Quote
markcoopers Posted May 17, 2005 Posted May 17, 2005 I thought it's a 2.8 sporting close, because of the 1st gear ratio? I thought you could have close or sporting close, with heavy duty versions of both, with two choices of 1st gear, 2.8 or 2.6. Richard, these are aftermarket boxes and quite sortafter. Basicly they are stronger and have a closer set of ratios, with 1st being a lot longer than standard. What engine is it hooked up to? Quote
davidgh Posted May 18, 2005 Posted May 18, 2005 2.8 (IIRC) because BGH fit them with needle roller bearings (as on the original Type 9 for the 2.8 Capri) -- allowing the box to handle more torque and more revs than the standard Type 9. There is a choice of three 'first' ratios (all much higher than the original) and three 'fifth's. Mine are 2.75 - 1.75 - 1.26 - 1.00 - 0.84 and I'm very happy. Price guide: ca. £1k (inc VAT) exchange -- which is why they are quite sought after. HTH Quote
scott beeland Posted May 18, 2005 Posted May 18, 2005 2.8 (IIRC) because BGH fit them with needle roller bearings (as on the original Type 9 for the 2.8 Capri) -- allowing the box to handle more torque and more revs than the standard Type 9. There is a choice of three 'first' ratios (all much higher than the original) and three 'fifth's. Mine are 2.75 - 1.75 - 1.26 - 1.00 - 0.84 and I'm very happy. Price guide: ca. £1k (inc VAT) exchange -- which is why they are quite sought after. HTH Same ratios as mine; but if I do ever get it rebuilt I might ask for a 2.66 1st instead Quote
Richard Houlgate Posted May 18, 2005 Author Posted May 18, 2005 Thanks for all your prompt replies. In my limited experience of driving the car first could probably be a little higher, apart from that its great especially 3 to 4. seethis site Any comments on the reverse gear stop I so urgently need to stop myself reversing into people at the lights? Quote
Richard Houlgate Posted May 18, 2005 Author Posted May 18, 2005 What engine is it hooked up to? Its a 2.1 litre pinto with fuel injection, dyno'd at 164bhp at 6275 rpm, max torque 150ft lb at 5000rpm. Big and heavy, not sure how this will affect the handling, but hopefully reliable! Quote
John Loudon - Sponsorship Liaison Posted May 18, 2005 Posted May 18, 2005 The gearstick bolts in with 3 bolts. I suggest that you could make something that could use these bolts to attach to the gearbox to block the path to reverse with the gearstick. I have seen something done like this before but cant remember what it actually looked like. If you have a quick shift fitted that uses an aluminium spacer between the gearstick and box, you could perhaps drill and tap a hole in its side to locate a stop bolt to achieve the same thing. John Quote
felters Posted May 19, 2005 Posted May 19, 2005 My type 9 had the same problem... I always selected 2nd first and then went straight forward to 1st... seemed to work Quote
