I don't know if this will help, but I have a VX220T where the dash is held in fundamentally by double sided sticky foam tape.  (There's a couple of self tappers as well but most of the work is done by the tape).  Much the same principle as the earlier suggestions of velcro - modern adhesives really do seem to be a viable alternative to traditional fixings and give just a tiny bit of damping to take out the vibration that tends to loosen orthodox fasteners.
As you're going to be using a wooden dash you need these Nut Pronged Tee things.
Ok, you still have to screw a bolt in from behind but you could use socket headed bolts which would be easier.
What you really need is something like a small bolt with a big flat / thin head on which you can glue to the back of the dashbord, and then carry as you would've with the old dash. I seem to remember some people use something like this for attaching cyclewings to the brackets
