pinto pete Posted May 16, 2005 Share Posted May 16, 2005 got half way to work today and she packed up found that the 10amp fuse had blown so i changed it for another and that blu aswell. i changed it for a 15amp, turned round and went home. i,ve done a serch and found some threds. is this common do you think the pump is packing up or just a bad earth its a brand new red top and i've only done 200 miles. many thanks for any information inadvance Quote Link to comment Share on other sites More sharing options...
studbuckle Posted May 16, 2005 Share Posted May 16, 2005 same symptoms for mine..... consensus was pump on the way out. new pump in and all is well with the world Quote Link to comment Share on other sites More sharing options...
pinto pete Posted May 16, 2005 Author Share Posted May 16, 2005 if i buy a new one should i try a mount it more upright the brackets on the westy leave it sitting somewhere between 30 and 45 degrees. i've heard they should be as upright as posible Quote Link to comment Share on other sites More sharing options...
Dave Smith Posted May 16, 2005 Share Posted May 16, 2005 This is quite a common problem with red top pumps. The same happened with my first one after 400 miles, sent it back to Westfield and they replaced it FOC. The new one's been fine for the last 4,500 miles, fingers crossed! Try sending it back, but if you do need a new one I've got a spare that I could let you have for a reasonable price PM me if you're interested. Quote Link to comment Share on other sites More sharing options...
Toby Mack Posted May 16, 2005 Share Posted May 16, 2005 happened to a mate of mine. After replacing the second fuse he noticed smoke from the pump turned out to be the feed wire had worn through and shorted on the case.... Might be worth checking. Quote Link to comment Share on other sites More sharing options...
pinto pete Posted May 16, 2005 Author Share Posted May 16, 2005 got a silver top now 5-6psi still enough for the 45s. did about 20 miles and it was ok so its off to work tomorrow the guy was a webber dealer he said this often happens to red tops and that silvers dont seem to have as much trouble. Quote Link to comment Share on other sites More sharing options...
