gatecrasher Posted May 1, 2005 Share Posted May 1, 2005 Hi all, just filling in my sva form and could do with some help on two things?? Maximum design road speed mph? Maximum power engine speed rpm? Im running a 2.0vx Any help would be great Thanx Si Quote Link to comment Share on other sites More sharing options...
jeff oakley Posted May 1, 2005 Share Posted May 1, 2005 I put on mine maximum road speed 120mph and max power at 5250rpm. You just need to make sure that the tyres are rated above the stated road speed on the form. Jeff Quote Link to comment Share on other sites More sharing options...
gatecrasher Posted May 1, 2005 Author Share Posted May 1, 2005 Thanx Jeff. the only thing i was worried about was the noise, i thought whatever rpm you put down, was how much rpm they gave it, to do the noise test ? Si Quote Link to comment Share on other sites More sharing options...
Flappa Posted May 1, 2005 Share Posted May 1, 2005 Noise test should be done at 3/4 max power rpm. 5250 = just under 4000rpm HTH Quote Link to comment Share on other sites More sharing options...
Greenstreak-Andy D Posted May 2, 2005 Share Posted May 2, 2005 Going through the same pains, but bit confused about the max power claim....so this isn't checked at SVA then? no proof of power output is required? Just the rpm quoted has to be JUST believable? Andy??? Quote Link to comment Share on other sites More sharing options...
jeff oakley Posted May 2, 2005 Share Posted May 2, 2005 I am pretty sure if you put down a reasonable figure they will not question it. You could always look in the haynes manual if you are concerned, but in genral if your engine revs to 6000 rpm peak power will be before that for a normal road engine. Obviously if you put down 5000rpm for a bike engined car they would spot that one straight away. Quote Link to comment Share on other sites More sharing options...
Motor-muzzy Posted June 2, 2005 Share Posted June 2, 2005 Hi, How much is the SVA test ? Quote Link to comment Share on other sites More sharing options...
Barry Ashcroft Posted June 2, 2005 Share Posted June 2, 2005 150 spot SVA Barry Quote Link to comment Share on other sites More sharing options...
Motor-muzzy Posted June 2, 2005 Share Posted June 2, 2005 Many thanks Barry. Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted June 2, 2005 Share Posted June 2, 2005 And around £30 for the obligatory retest Quote Link to comment Share on other sites More sharing options...
Motor-muzzy Posted June 2, 2005 Share Posted June 2, 2005 Thanks for the vote of confidence Quote Link to comment Share on other sites More sharing options...
KerryS Posted June 3, 2005 Share Posted June 3, 2005 ..but some pass first time Kerry S Quote Link to comment Share on other sites More sharing options...
sportstergray Posted June 3, 2005 Share Posted June 3, 2005 Jeff, I went trough the same last year on SVA unfortunately I put down the Max revs (6400) in the toque box & subsequently had the noise tested at 4800 revs. (75% 0f max) & I failed at 104Dbs. The test officer was very good & explain the figure for a 1800 Zetec should be more near the 5500, but had to fail it as the official forms stated those values to be tested at. An official letter from WFs sorted it out for the re-test & it passed at 96Dbs. So don’t make the same mistake. The advise from the other guys here is sound (no pun intended) If it helps, the figures for my 1800 Zetec are:- Max Speed 126mph Max Revs 6400 Max Torque 5400revs :- Tested at 4050 revs Result: 96Dbs Good luck with the SVA, I’m sure you have read all the comments on hear about preparation for the SVA, all sound advice. Gray Quote Link to comment Share on other sites More sharing options...
