Guest Posted April 26, 2005 Posted April 26, 2005 Which of the Tyrespot depots in Darlington did you use for your exhaust. I need a stainless steel link made from manifold to silencer. Thanks, JD Quote
JeffC Posted April 26, 2005 Posted April 26, 2005 I used the one on mcmullen road... u may have to leave it with them... i took mine on a saturday morning when they were a little busy and they werent so keen had to twist there arm a bit! mine wasnt so bad as i had one allready and just needed a bigger version making.... I think all there branches do stainless welding , i did a google search on exhaust fabrication and tyre spot comes up... also "exhaust a fix" on whessoe road behind morrisons do it as well.. hope you get sorted... Quote
Guest Posted April 26, 2005 Posted April 26, 2005 Many thanks. I will try to book an appointment for Friday morning. Cheers, John Quote
