Crossflow Missfire and Engine Rattle
Had a similar problm with a X flow car  long time ago, and was starter motor related. This would also explain why it started after you restarted the car, having just used it.
Poping and bangng and rought running might be a function of heat soak, having switched the engine off and filled up. This may be enough to vapourise any fule/ cause you hot running issues, whilst today (cold) and earlier (getting up to temp) it was fine.
2 unrelated problems that coincide with restarting the car.
