davew Posted April 22, 2005 Posted April 22, 2005 After failing sva because of loud exhaust (108db) with a second hand standard westfield silencer. I have been looking at the new westfield repackable silencer, however I can only find one post about it. Who's got one and what sound level do you get/engine spec. I have a 2l zetec on twin 45's Quote
CocoPops Posted April 22, 2005 Posted April 22, 2005 I think the "WunOff" repackable exhausts are popular on here as well? <<< That car SVA'd at 98 dB with one and aVX 2.0 XE with Throttle Bodies. Quote
Bazzer Posted April 22, 2005 Posted April 22, 2005 Bigger the better really. If you are planning on doing track days save your self cash and go for a 7" x 30" can now, which is pretty much as big as you can fit in. If you dont you will only end up replacing the one you buy now with a bigger one. Cheers Bazzer Quote
felters Posted April 22, 2005 Posted April 22, 2005 Raceline and Raceco seem popular... they are monsters but do the job. Just ordered a Raceline 7.25" dia. x 80cm for my Blade... Quote
Bazzer Posted April 22, 2005 Posted April 22, 2005 Yep thats the ticket. I have a Techcraft which works noise wise, but I know some people on here have had problems with welds braking though. Bazzer Quote
chazpowerslide Posted April 22, 2005 Posted April 22, 2005 We tested two cars at Oakington this evening with the Westfield repackable silencers on. Mine (2ltr Zetec on 45 webers) made 89dba Chris Finlay's car (2lt VX with 45 Webers) at 88dba I think this is a little optimistic really but the Westy re-packable silencer is really quiet. I'd recommend it. Chaz. Quote
ChrisF Posted April 22, 2005 Posted April 22, 2005 As Chaz says, my Vx tested very quiet and I can also recomend the quality of the westfield exhaust Quote
davew Posted April 23, 2005 Author Posted April 23, 2005 A remorgage and a westfield repackable silencer coming up then! Anybody got any pictures? Is the mounting the same as the standard westfield mount? Quote
Dave Eastwood (Gadgetman) Posted April 23, 2005 Posted April 23, 2005 Don't suppose anyone could post some pictures of how they've fitted the mounts could they? Had to bend mine about a bit to get them to fit, and now starting to wonder Quote
ciscobay Posted April 23, 2005 Posted April 23, 2005 Fitted mine to westfield manafold without any bending got no pics can take some tomorrow done a trackday three weeks ago 90 decibels 1800 zetec on throttle bodies cisco Quote
ChrisF Posted April 23, 2005 Posted April 23, 2005 Had to bend mine about a bit to get them to fit, and now starting to wonder Mine was a bend it and amend it job Westfield did tell me that the repackable silencer was not designed as a direct replacement as there are so many variants. I had to fiddle about with the mountings and use some of the old mountings to make it all fit to my wesfield Vx manifold. Quote
8336 Posted April 24, 2005 Posted April 24, 2005 I've got the Westfield re-packable, Zetec 2.0 on 45s, I've not had it metered but it is pleasantly quieter than the standard can. I had to fettle mine to fit - the angle of the pipe into the can didn't work on my car, it wanted the back of the can to go into the passenger area! So I got an SS welder to cut and re-weld. Neat job, £20. I foolishly didn't loctite bolts into can for conformal bracket. About 70 miles later I heard rattling and found thay had fallen out! Jury rig with wire coathanger as Sunday and no replacements available. Thought about taking on of other can end fixings out to substitue, but too short. Sourced some suitable replacents and bought some loctite. John G Quote
ciscobay Posted April 24, 2005 Posted April 24, 2005 some photo's of my exhaust with no mods except wire ties around mount had one separate before. Quote
Steve20 Posted April 24, 2005 Posted April 24, 2005 Does this silencer avoid the need for the heat shield at SVA ? Quote
